I will have to say that getting ntinhri’s truck dialed in has been a long hard process. A good while ago I met him at a meet in Maryland and put a wideband on his truck to check what his AFRs were. The TRD Superchargers had just come out and I think his was the second one I tested.
His truck ran super lean in boost. How this truck did not blow up is beyond me. So, it became a long term project truck to get this thing running correctly.
The first attempt to tune it was a failure. I simply could not get it to richen up sufficiently. I tuned it with a MAP-ECU2 and it would tune to a point then just be stupid lean.
I rigged up a 7th injector system similar to what we used on the URD Supercharger kit and installed it. Started with a 440cc injector. No change. Moved to a 750cc injector. No change. Dropped in a 1000cc unit and basically made no difference. It was clear the fuel pump was not getting enough fuel to the engine to properly fuel it.
By this time my 3rd OEM, pump assembly was starting to get another plugged up fuel filter so it was clearly time to solve this pump filter problem. I ripped into my fuel tank and figured out how to get a high flow pump in there and switch it from a tiny in the tank filter it a large external fuel filter that would not plug up on my every 30,000 miles. It worked and I made a second kit for ntinhri’s truck and sent it off to him.
After the pump was installed it had plenty of fuel and we removed the 7th injector from the truck and retuned it with the MAP-ECU2.
His truck had a real bad lean out problem right as it was eased into boost. I was able to cure that through tuning and the midrange really came alive. However it would stop responding to MAF sensor value changes past a certain load point and high load tuning was ineffective. This was the 3rd truck that I played with that had the TRD reflash that basically stopped looking at the MAF sensor at a certain point and was untenable past there. However; with a couple little tricks of mine, I was able to add just enough fuel to get a proper fuel mixture in that last lean area.
Now his truck was running very strong, and now finally had a safe AFR, but,,,
Ntinhri was the lucky winner of the X-1 that URD gave away at XFest.
URD was involved very early on in the X-1 development back in early 2005 and finally it is released. It is no secret now that we are going to use it with our new high power supercharger system and have been working very hard on identifying areas where it can be improved. It was a wonderful controller when it came out and gets better all the time. I have been working with Scott from APR, testing and retesting many new features and changes in the control logic. The latest update was completed at midnight Sunday and I loaded it into his X-1 after it was installed.
The new update worked flawlessly in his truck. Make no mistake, for a TRD truck it runs pretty damn good and strong. The fuel control is spot on under all conditions.
I am sure some of you are wondering what is so different about the X-1 as opposed to other tuning products out there. The most important feature is the way it controls the fuel.
The X-1 drives the injectors and igniter coils directly. Below a certain point it will follow what the stock ECU is doing, but after a point it will take full control and run the engine directly. While it is driving the engine directly it will feed back signals to the ECU to make it think it is still running the engine to keep it happy. So it is essentially a standalone EMS that keeps the stock ECU happy.
It will self adjust its self to get to and keep the AFR at the programmed AFR. It does this using feedback from the two front air/fuel ratio sensors in the exhaust manifolds. This way it is always spot on and it will not change with the weather, altitude or other ambient conditions.
If it cannot keep the AFR where it is supposed to be by more than a certain amount for a given time, it will engage the engine guardian feature to alert you something is wrong. It does this by turning on the check engine light steady. It can also radically lower the rev limit to give you a clue and get your attension. If you have a turbo it can pop the waste gate to cut boost. The guardian will also lower the rev limit if it overheats. The ability to derate the power can save the expensive engine if something very simple happen like your fuel filter plugs up. A simple thing like that can be very expensive on a boosted engine if you don’t know it.
One of the features that I really love is the logic in the fuel control FIXES THAT JERKY 1st to 2ND GEAR SHIFT!!!!
For those of you considering getting the TRD Supercharger, I would recommend that you do not get the ECU reflash. Just get the X-1 and the engine will run wonderfully. Remember, once you flash the ECU you cannot go back. With the X-1 instead you can remove the supercharger and X-1 down the road if you sell, trade, or crash your truck and sell it separately and recover more of your money.
If you did get the reflash, don’t worry, the X-1 overides the buggy reflash.
Those of you with a normally aspirated truck, there is a great program for you as well.
If you have a URD Supercharger system we will have a program for you very soon if you want to upgrade.
Just to give you a little teaser of things to come, I have gotten some serious power out of my own XRunner lately. Even more than the published dyno chart that showed 402 RWHP.
There was a recent price increase on the X-1 kit by $200 to $1495. URD still has a few kits in stock at the old price. If you are interested in getting one and save a little money, act fast. With our next stocking order we will likely be raising the price.
If you have any specific questions about the X-1 please let me know.
