Venomous_X
- May 11, 2008
- 13,694
- 2
I doubt it, but is this your wheel?
SignUp Now!Yes that is the style. But when I run them it will be minus that F'ugly aluminum center cap. That cap looks like a dang nipple. I'll take a pic when I get home of the wheel without it when I get home from helping Grumpy bleed his brakes.
so what you gonna run now? bigger turbo or staying with the same one and just upping the boost? 20psi??
I might up the boost a little. Not much though, if I do. There are some improved efficiency plans for down the road.
When it becomes a reality, I'll be able to turn down the boost to make the same power.
Like I said, that's down the line.
As a refresher, my new compression ratio is 9.2:1
That's easy... turn down the boost to about 7 - 8 and have a gt35r on there instead of that t28 .... :laugh: Nice CR but with all that motor work and power... i'm really surprised to not hear about your tranny.... maybe these 5 speeds are a bit stronger than ours.... or are you auto?.... as far as motor work goes though..... What brand are you going with on all these if you don't mind me asking? Especially the valve train.... I know it's custom for the most part but the custom parts have to be coming from a branded company.... skunk2, tomei, etc....
Mark's mod list, pay attention to the last one
Pro Comp 6" lift [] 35" KM2's [] NST Pulley set [] Custom Rear-mount turbo [] TiAL Q BOV [] TiAL V44 W/G [] Greddy Profec B II Boost Controller [] APR X-1 [] DTLT [] URD Y-Pipe [] 668 Injectors [] Walbro 255 LPH Fuel pump [] Fidanza Flywheel [] Spec Stage 3+ Clutch
